Customized shortpass 950 nm filter 8 OD with customized 5 x 5 mm size (certified)
Shortpass optical isolator with a 950 nm cut off wavelength (CWL),and wide-range OD6 out-of-band blocking from 1000 nm to 1900 nm. This is a multi-cavity filter with exceptionally steep edges, a flat…
Read More…Shortpass optical isolator with a 950 nm cut off wavelength (CWL),and wide-range OD6 out-of-band blocking from 1000 nm to 1900 nm. This is a multi-cavity filter with exceptionally steep edges, a flat top, and shortpass transmission that is greater than 90%. This ultra-narrowband filter is coated on a 2 mm thick Borofloat® substrate.
Enter your email address if you'd like to be notified when Customized 950 nm cutoff short pass filter > 6OD can be shipped to you:
Prajnesh | Aug. 4, 2021
Flea Market Item:
$56.00
$145.00
