Simple adapter PCB to use noval tubes in prototyping or easier in point to point wiring applications.
Designed by C-Audio in Germany
What is it? An adapter PCB for noval tubes (9-Pin, such as ECC83, ECC82, EF86, EL84, ect.) to simplify prototyping and deploying of tubes in circuits. Why did i make these? I made these after fussin…
Read More…An adapter PCB for noval tubes (9-Pin, such as ECC83, ECC82, EF86, EL84, ect.) to simplify prototyping and deploying of tubes in circuits.
I made these after fussing around with chassis mount tube sockets in a few builds. I found it somehow tedious to have the pins so close to each other, to always have to have a few anchor points nearby for point to point wiring projects and to mount the socket itself.
All PCBs are supplied with a manual to outline all possible usecases of the boards. If you want a digital version just DM me.
Enter your email address if you'd like to be notified when Noval Tube Prototyping Adapter can be shipped to you:
| Quantity | Price |
| 1-9 | $4.00 |
| 10+ | $3.00 |
$1.00
$1.49
