Raytac’s MDBT40 series Bluetooth module deployed Nordic nRF51822 solution, Pre-Certified of BQB, FCC/IC/CE/Telec/KC/SRRC/NCC
Raytac's Modules 100% Made In Taiwan; No worry about the Trade War Risk With China! Raytac’s MDBT40 is a BT 4.2 & BT 4.1 & BT4.0 stack (Bluetooth low energy or BLE) module designed based on Nordi…
Raytac’s MDBT40 is a BT 4.2 & BT 4.1 & BT4.0 stack (Bluetooth low energy or BLE) module designed based on Nordic nRF51822 SoC solution, which incorporates: GPIO, UART, I2C and ADC interfaces for connecting peripherals and sensors
Bluetooth Certification: BT4.2 & BT4.1 & BT4.0 Safety Regulation Compliance: FCC (USA) / IC (Canada) / CE (EU) / Telec (Japan) / SRRC (China) / KC (Korea) / NCC (Taiwan)
Solution: Nordic nRF51822 Solution:
About The Module:
Dual Transmission Mode of BLE & RF 2.4G upon customer preference.
Compact size with (L) 18 x (W) 10 x (H) 2.7 mm
Compatible with a large installed base of mobile phones, tablets and computers.
Fully coverage of BLE software stack including:
Proximity Profile; Heart Rate Profile; Health Thermometer Profile; Blood Pressure Profile; Running Speed & Cadence Profile; HID Over GATT Profile; Alert Notification Profile; Glucose Profile; Cycling Speed & Cadence Profile
Features:
2.4GHZ transceiver
. -93dbm sensitivity in Bluetooth low energy mode
. TX Power -20 to +4dbm
. RSSI (1db resolution)
. ARM Cortex – M0 32 bit processor
. Serial Wire Debug (SWD)
. S100 series SoftDevice ready
. Memory
. 256kb or 128kb embedded flash programmed memory
. 16kb RAM or 32kb RAM
. Support for non-concurrent multiprotocol operation
. On-air compatibility with nRF24L series
. Flexible Power Management
. Supply voltage range 1.8V to 3.6V
. 2.5us wake-up using 16MHz RCOSC
. 0.6uA @ 3V mode
. 1.2uA @ 3V in OFF mode + 1 region RAM retention
. 2.6uA @ 3V ON mode, all blocks IDLE
. 8/9/10 bit ADC- 8 configurable channels
. 31 General Purpose I/O Pins
. One 32 bit and two 16 bit timers with counter mode
. SPI Master
. Two-wire Master (I2C compatible)
. UART (CTS/RTS)
. CPU independent Programmable Peripheral Interconnect (PPI)
. Quadrature Decoder (QDEC)
. AES HW encryption
. Real Timer Counter (RTC)
Enter your email address if you'd like to be notified when nRF51822 BT4.2 Module MDBT40 Chip Antenna can be shipped to you:
Ships from Taiwan.
3 Reviews | 230 Orders
$9.90
$7.20
