Nordic nRF52805 BT5.2 AT Command Slave/Peripheral Bluetooth Small Module UART SPP Service Raytac MDBT42T
Designed by Bluetooth & WiFi Module in Taiwan
Raytac's Modules 100% Made In Taiwan; No worry about the Trade War Risk With China! Raytac's AT Command Module (Salve/Peripheral) Bluetooth Certification: BT5.2 Safety Regulation Compliance: FCC …
Bluetooth Certification: BT5.2 Safety Regulation Compliance: FCC (USA) / IC (Canada) / CE (EU) / Telec (Japan) / SRRC (China) / KC (Korea) / NCC (Taiwan)
About The Module:
Nordic nRF52805 Solution Compact size with 7.2 x 11.2 x 1.8 (2.05)mm.
Antenna Option - Chip Antenna: Raytac P/N: MDBT42T-AT - PCB Antenna: Raytac P/N: MDBT42T-PAT
Enter your email address if you'd like to be notified when AT Command Slave BT5.2 Small Module MDBT42T can be shipped to you:
Ships from Taiwan.
3 Reviews | 227 Orders
$6.30
$6.80
