Nordic Solution AT Command Slave/Peripheral Bluetooth Module UART SPP Service Raytac MDBT42V Series
Raytac's Modules 100% Made In Taiwan; No worry about the Trade War Risk With China! Certification: Bluetooth: BT5.2 & BT5.1 & BT5 & BT4.2 Regulation: FCC/IC/CE/Telec/SRRC/NCC About The Module: No…
Certification:
About The Module:
Nordic nRF52832 Solution, Slave (Peripheral) Role
Compact size with (L) 6.4 x (W) 8.6 x (H) 1.5 (1.75) mm.
Antenna Option
Enter your email address if you'd like to be notified when AT Command Slave BT5.2 Module MDBT42V can be shipped to you:
Ships from Taiwan.
3 Reviews | 227 Orders
$6.80
