12V:5V/2A buck power supply
Designed by Yann Leidwanger in France
This usefull compact modules is a buck power supply based on dedicated IC Due to specificties of some systems (available power supply and required poswer supply), I designed this compact and powerful…
Read More…This usefull compact modules is a buck power supply based on dedicated IC
Due to specificties of some systems (available power supply and required poswer supply), I designed this compact and powerfull DC/DC module :
Iout up to 2A without thermal heatsink
ENABLE pin (tie pin to GND to disable, default enabled with on-board pull-up resistor)
EMC improved routing and decoupling
power-on green LED
compact size = 20mm x 21mm
pinout on bottom silkreen
Try it !
Enter your email address if you'd like to be notified when Compact and powerfull DC/DC module can be shipped to you:
$16.99
