Three oscillators drone with distortion control, in Eurorack format
Designed by TOMA Systems in Italy
Description This module consists of 3 ramp oscillators, each with different range of frequencies, mixed together and processed by a diode distortion stage with dry/wet control. The oscillators are ma…
Read More…This module consists of 3 ramp oscillators, each with different range of frequencies, mixed together and processed by a diode distortion stage with dry/wet control.
The oscillators are made with NPN reverse biased transistors, as shown in this video of Look Mum No Computer.
I added the mixing circuit, the distortion stage and made frequency ranges slightly overlapped, making this module capable to create very wide and powerful chord-like sounds.
Selection | What you'll get |
PCB Only | PCB |
DIY Kit | PCB, Panel, All electronic components, Knobs, 25cm ribbon cable |
Fully Assembled | Ready to plug module, 25cm ribbon cable |
Enter your email address if you'd like to be notified when TS-203 Multichords can be shipped to you:
Documentation: (4.00)
Shipping: (4.00)
Communication: (4.00)
Costantino | Jan. 24, 2020
$3.50
$17.00
