External Ultrasonic Distance sensor Module with a prototype PCB and an additional Thermometer + Humidity sensor .
Designed by The Wired Hatters in Germany
Specifications: Custom Board -HC-SR04 -DHT 11 Compatibility: This custom module is compatible with all newer versions of Unleashed, Rougemaster, or Xtreme for the Flipper Zero! Initial Setup: This mo…
Read More…Specifications:
Compatibility:
Initial Setup:
This module operates via the apps " [HC-SR] Dist.Sensor " and "Temp sensor Reader" of the Flipper Zero with custom firmware.
Make sure to switch to the "10SCW" option in the "DHT11"/"DHT12" menu.
Remember to select sensor module "DHT11" or "DHT12"
All modules are thoroughly tested before shipping to ensure they are fully functional. - comes without flipper
Join our discord Main Shop Make sure to check my Instagram to be up to date and so you can contact me whenever 🙂 --> @TheWiredHatters
⚠️ WARNING ⚠️
I do not condone illegal activity and strongly encourage keeping transmissions to legal or valid educational or experimental uses allowed by law. Please be advised that the products sold here are third-party items that are compatible with the Flipper Zero. These products are not manufactured, endorsed, or affiliated with Flipper Devices Inc. in any way. The use of the "Flipper" or "Flipper Zero" name in our product descriptions is for identification purposes only, to demonstrate the compatibility of our products with the mentioned device
Enter your email address if you'd like to be notified when distance + temp + humidity module AIO can be shipped to you:
$173.25
$32.50
$38.90
$49.80
$49.80
$11.90
