Mini 3V LED spotlight with lens—perfect for models, robotics, wearables, and more. Bright, compact, and easy to mount anywhere.
What is it? Bring focused illumination to your project with this Mini White LED Bright Spotlight / Flash Module 3V, featuring a precision-engineered lens and compact breakout board. Whether you're li…
Read More…Bring focused illumination to your project with this Mini White LED Bright Spotlight / Flash Module 3V, featuring a precision-engineered lens and compact breakout board. Whether you're lighting up a display box, creating lighting effects in a model, or adding a functional beam to a robotics build, this module delivers impressive brightness and clean optics in a small package.
Features:
Perfect for:
Use it as a standalone spotlight, chain several together, or embed them inside enclosures for subtle but powerful illumination. This module is a plug-and-play favorite for rapid prototyping and refined builds alike.
Note: Be sure to add a current-limiting resistor if you're using an unregulated power source. The module includes a resistor for 3V typical use, but extra caution is recommended for voltages beyond that range.
If you are looking for a flat illumination instead, check out our: FlexiGlow: Flat Flexible LED White Backlight Panel
Enter your email address if you'd like to be notified when Mini White LED Bright Spotlight / Flash Module 3V can be shipped to you:
$12.80
$24.80
$2.50
$17.80
$13.80
$17.80
$13.50
$9.88
