Inject custom power and data into Micro-USB devices using your own circuits—ideal for embedded, battery, or solar-powered projects.
What is it? This isn't your typical USB breakout. Unlike most boards designed to receive signals, this Male Micro-USB Breakout Board is made to drive them. Designed to plug directly into devices with…
Read More…This isn't your typical USB breakout. Unlike most boards designed to receive signals, this Male Micro-USB Breakout Board is made to drive them.
Designed to plug directly into devices with a female Micro-USB port, this breakout lets you inject your own power and data signals into USB-enabled devices. Whether you're building a custom charger, testing a USB device with non-standard power sources (like batteries), or sending USB signals from a microcontroller, this board gives you clean and direct access to the Micro-USB interface.
Features:
Unique Use Cases:
Custom Power Injection: Power Micro-USB devices (e.g., Raspberry Pi, Arduino, Wi-Fi dongles) using battery packs or bench power supplies—no need for USB cables.
Microcontroller-to-USB Device Communication: Connect D+ and D- directly to the USB-capable pins of microcontrollers like the STM32, RP2040, or ATmega32u4 to simulate USB host/device behavior.
DIY Charging Solutions: Use with solar chargers, boost converters, or regulated battery packs to charge USB devices in custom enclosures or remote setups.
Embedded Integration: Seamlessly integrate into your enclosures to turn your project into a plug-in USB power or data source.
Enter your email address if you'd like to be notified when Male Micro-USB Breakout Board: Inject Power & Data can be shipped to you:
$17.80
$13.80
$17.80
$17.90
$6.80
