MICRO AR DISPLAY 0.57 INCH 1600(RGB)×1200 HIGH RESOLUTION 1800NITS HIGH BRIGHTNESS seeya OLED MICRODISPLAY MIPI for ar glasses vr headset
Micro oled screen 0.57 inch 1600(RGB)×1200 (UXGA) 1800cd/m2 micro display MIPI for Head-mounted Displays (HMD),viewfinder,Head-Mounted Displays (HMD) summary of 0.57" micro oled screen 1600x1200: The…
Read More…micro oled screen 0.57 inch 1600(RGB)×1200 (UXGA) 1800cd/m2 micro display MIPI for Head-mounted Displays (HMD),viewfinder,Head-Mounted Displays (HMD)
The micro display is a 0.57 inch diagonal Si-OLED display screen product from SeeYA, it self emiting, without touch screen. this microoled display supports display 1600(RGB)×1200 (UXGA) with aspect ratio of 4:3 (W:H), whose pixels are arranged in RGB Vertical Stripe, it's pixel density is 3527 PPI. As for mechanical detail, it features active area of 11.52(W)×8.64(H) mm, outline size of 21.087(W)×22.765(H) mm. the micro oled display can provides 1800 cd/m² display brightness 50000:1 transimissive contrast ratio ., also applicable for the medical and military industry such as Head-mounted Displays (HMD),viewfinder,Head-Mounted Displays (HMD) etc.
0.57 inch Si-OLED micro display
Application:AR VR devices, EVF, Night vision, sight...
0.57" 1600x1200 Micro display Screen Features
Mechanical Drawing
Mechanical Drawing of HDMI Controller Board:
Mechanical Drawing for Binocular TYPE-C Controller Board:
0.57" 2560*2560 Micro display Screen Applications:
Enter your email address if you'd like to be notified when 0.57 inch micro ar display 1600x1200 MIPI can be shipped to you:
$185.00
$435.00
$185.00
$135.00
$238.00
$105.00
$149.00
$235.00
$539.00
$185.00
$149.00
$149.00
