TPS62840 is a high-efficiency buck converter with ultra-low operating quiescent current of 60 nA, 20nA shutdown and 750mA max output current
Designed by MakerTronika Labs in GermanyNo shipping info available.
What is it? olmBoard is a small and a breadboard-friendly, ultra-low-power buck converter module with TPS62840 step-down converter at its heart. Check out this excellent review from @Voltlog on his …
Read More…olmBoard is a small and a breadboard-friendly, ultra-low-power buck converter module with TPS62840 step-down converter at its heart.
Check out this excellent review from @Voltlog on his YouTube channel.
TPS62840 is an ultra-low-power switching regulator from Texas Instruments. It offers super low operating quiescent current (IQ) at 60 nA, and delivers very high light-load efficiency of 80% at 1-µA load.
The TPS62840 IC provides an output current of up to 750 mA. With the input voltage from 1.8 V to 6.5 V, the device supports multiple power sources such as 2S to 4S alkaline, 1S to 2S Li-MnO2, and 1S Li-Ion/Li-Po/Li-SoCl2. JST-PH connector has also been added for easy battery connections.
Some specs:
Initial sweep load test results w/ 0.1A at 10 sec increments using EBD-USB load tester is shown below. The module works well up to 1A loads (short term), and recommended max. output current is 750mA. Voltage drop in the graph is due to the USB cable drop, actual voltage is stable around 3.3V up to 1A loads.
I needed a ULP buck converter module for my Penguino Feather board and this IC sounded very promising. I decided to give it a try and build a small module to test it out.
This IC offers some unique features and it's one of the lowest operating current buck converters I've ever seen. Additinally it has a selectable output voltages (default 3.3V) with solder-jumper selectable ranges from 1.8V to 3.3V.
Enter your email address if you'd like to be notified when olmBoard - TPS62840 ULP Buck Converter 60nA Iq can be shipped to you:
Claus | Feb. 22, 2021
$8.49 $9.99
$8.49 $9.99
$16.99
