Sensor board containing LIS2DH12 Accelerometer
Designed by LEK Electronics in Singapore
What is it? The LIS2DH12 Accelerometer Board is a compact sensor module based on the ultra-low-power, high-performance three-axis linear accelerometer from ST. Key Applications: Display orientatio…
Read More…The LIS2DH12 Accelerometer Board is a compact sensor module based on the ultra-low-power, high-performance three-axis linear accelerometer from ST.
Key Applications:
Display orientation
Impact recognition and logging
Shake/Vibration detection
Pedometer
Gaming input devices
Featuring:
On-board 3.3V regulator – easy power integration
8-pin XH header for power and signal connections
Multiple host interfaces: I²C, SPI
User-selectable accelerometer range: ±2 g to ±16 g
The LIS2DH12 is largely compatible with the LIS3DH, with many registers and pins located in the same positions. I designed this module to help test the LIS2DH12’s compatibility in LIS3DH applications.
Enter your email address if you'd like to be notified when LIS2DH12 Accelerometer can be shipped to you:
$13.50
$5.20
$2.00
$2.00
$6.70
