JP332A regulator - stabilize voltage for hobbyist & pro projects. 3.3V and 2A output for sensors, Arduino & Raspberry Pi. Small, efficient
Designed by JP IonTic in CzechiaThis product is no longer available for sale.
$99.99 $124.99
$254.15 $299.00
$297.00
Introducing the JP332A voltage regulator - the perfect solution for powering your development modules and IoT sensors with ease and stability. With a fixed output voltage of 3.3V and the ability to h…
Read More…Introducing the JP332A voltage regulator - the perfect solution for powering your development modules and IoT sensors with ease and stability. With a fixed output voltage of 3.3V and the ability to handle input voltages ranging from 3V to 5.5V (absoulute maximum 6V), the JP332A ensures your projects run safely and smoothly. You do not need to worry about not having enough juice. The output current is up to 2amps (2.25amps absolute peak current)! Thats enough for any IoT or diy project.
The JP332A is powered by the highly efficient TPS62A02 integrated chip from Texas Instruments, which allows the module to achieve an impressive efficiency of up to 95%. This means that the JP332A minimizes wasted energy, making it an environmentally-friendly solution for your projects.
Designed for hobbyists and professionals alike, the JP332A is compact and easy to use. With a small PCB that measures just 14mm by 8mm, the JP332A is perfect for integration into any project. The PCB also features holes for attaching a 2.54mm pitch header, making it easy to connect to your development modules or IoT sensors.
The JP332A is ideal for powering development modules like Arduino, Raspberry Pi, and other microcontrollers. It's also perfect for IoT sensors and modules that require a 3.3V power source. Whether you're a hobbyist or a professional, the JP332A voltage regulator is an essential tool for your projects.
So why wait? Purchase the JP332A voltage regulator today and take your projects to the next level with safe, stable, and efficient power!
1 | $2.50 |
2-9 | $2.30 |
10-39 | $2.10 |
40-99 | $2.00 |
100+ | $1.90 |
$11.99
$2.50
$3.25
$7.03 $7.99
