The FMC Height Extender is a board designed to increase the vertical spacing between FPGA carrier cards and FMC mezzanine modules.
Features VITA 57.1 FMC form-factor height extender card Compatible with LPC (low-pin-count) and HPC (high-pin-count) boards High-Pin-Count (HPC) VITA 57.1 male connector HPC VITA 57.1 female …
Read More…Features
HPC VITA 57.1 female connector
Full 400-pin direct pass-through connectivity
Flexible I/O voltage (VADJ) support
Supports convenient use of non-standard carrier and mezzanine card outlines
Stackable assembly
Open-source hardware
Applications
Extending board-to-board spacing for FPGA carrier and mezzanine cards
Facilitating additional I/O expansion during prototyping
Extending lifecycle of FPGA carrier card FMC connectors in test platforms
Research and education with FPGAs
Description
The FMC Height Extender is a passive PCB module designed to increase the vertical spacing between an FPGA carrier card and an FMC mezzanine module in compliance with ANSI/VITA 57.1 FPGA Mezzanine Card (FMC) Standard. It provides a high-pin count (HPC) male connector on one side, and an HPC female connector on the other, routing all 400 pins directly through. This enables enhanced accessibility and flexibility during prototyping or testing of FMC I/O interfaces. The module is fully compatible with both FMC LPC and HPC modules, ensuring maximum flexibility for all types of designs. In addition to its standard functionality, the height extender also supports the convenient use of non-standard compliant FMC cards. If a carrier card places components inside the forbidden regions defined by the FMC outline, or if a mezzanine module has a larger outline than standard FMC modules, the extender adds mechanical clearance. This allows engineers to combine otherwise incompatible carrier and mezzanine cards without redesigning hardware.
The full datasheet is available at https://fmchub.github.io/projects/FMC_HPC_HEIGHT_EXTENDER/Datasheet/FMC_HPC_HEIGHT_EXTENDER_datasheet.html
Enter your email address if you'd like to be notified when FPGA Mezzanine Card (FMC) HPC Height Extender can be shipped to you:
| Quantity | Price |
| 1 | $139.00 |
| 2-3 | $125.00 |
| 4-5 | $118.00 |
| 6-7 | $111.00 |
| 8-9 | $104.00 |
| 10+ | $97.00 |
$245.78
$170.52
$245.00
$249.00
$175.22
$249.00
$410.42
$234.02
$124.42
$234.02
$170.52
