External CC1101 Antenna Module with Custom PCB Sub-GHz Range Extender and Antenna for the Flipper Zero
Designed by Flipper_AddOns in Germany
NEW VERSION 2.0 -More Power (More range) -Even smaller than V1.0 (uses 5v now) -Less line noise -Build in LED -Custom “PinballAddOns” design -NOW with high-gain antenna External CC1101 Antenna Module…
Read More…NEW VERSION 2.0 -More Power (More range) -Even smaller than V1.0 (uses 5v now) -Less line noise -Build in LED -Custom “PinballAddOns” design -NOW with high-gain antenna
External CC1101 Antenna Module with Custom PCB Sub-GHz Range Extender and Antenna.
Make sure to check my Instagram to be up to date and so you can contact me whenever 🙂 --> @flipper_addons
Price per unit comes without Flipper zero
Specifications: -Custom CC1101 External Range
Compatibility:
This custom module is compatible with all newer versions of Unleashed, Rougemaster, or Xtreme for the Flipper-Zero!
Initial setup:
This module operates via the 5v output of the Flipper-Zero.
Make sure to turn on the 5v option in the GPIO Settings of the pinball--> lights up LED and is ready to use
Remember to change the "Module" option from "Internal" to "External" under the "Radio Settings."
⚠️ WARNING ⚠️
Enter your email address if you'd like to be notified when V2.0 - Flipper-zero sub-GHZ Booster module can be shipped to you:
$42.00
