The one board every maker needs. CP2102 USB to UART(TTL) converter onboard with all pins taken out and with adjustable output voltage.
This little adapter converts USB communication to UART using Silabs CP2102. Everything is packed on a small board. In addition to standard UART pins arranged in standard order: DTR, RXD, TXD, VCC, CT…
Read More…This little adapter converts USB communication to UART using Silabs CP2102. Everything is packed on a small board. In addition to standard UART pins arranged in standard order: DTR, RXD, TXD, VCC, CTS, GND, other pins from the chip are available on the board: RST, Suspend, Suspend ', RI, DCD, DSR , RTS, CTS.
In addition, the board is a voltage regulator and a switch, it is possible to determine the output voltage of 3.3V or 5V, depending on the device you are using. Logic UART signal is always 3.3V, but do not worry, 5V devices will work without problems. There are also three LEDs, one for power indicator and one for each direction of UART communication.
This board has been manufactured in Croatia by e-r.io: Blog, Github, Web store.
1-4 | $4.63 |
5-9 | $4.42 |
10-19 | $4.20 |
20+ | $3.98 |
Ships from Croatia.
9 Reviews | 281 Orders
$22.95
$7.95
$5.50
$3.95
$23.95
$16.95
$7.95
$2.95
$59.00
$24.99
$7.95
