The USB Type-C is ubiquitous. We always wanted to add it to our electronics projects, and we’re sure you did too.
The USB Type-C is ubiquitous. We always wanted to add it to our electronics projects, and we’re sure you did too. Adding a USB Type-C connector to your projects is easier than ever thanks to this USB…
Read More…The USB Type-C is ubiquitous. We always wanted to add it to our electronics projects, and we’re sure you did too. Adding a USB Type-C connector to your projects is easier than ever thanks to this USB Type-C breakout board. It will allow you to send data to your device, as well as add power to the circuit.
The USB Type-C connector’s GND, CC2, SBU2, D-, D+, SBU1, CC1, and VUSB pins are broken out to the plated through-holes.
Find USB-C female connector breakout on Soldered website.
Enter your email address if you'd like to be notified when USB-C female connector breakout can be shipped to you:
Ships from Croatia.
9 Reviews | 281 Orders
$22.95
$7.95
$5.50
$3.95
$23.95
$16.95
$7.95
$2.95
