The goal of this game is to press buttons in order as they light up.
$23.40
$33.60
$31.96 $39.95
If you are looking to start learning how to use a soldering iron or want to create a small portable gadget this set is a great chance "Simon Says" game educational set for learning with soldering iro…
Read More…If you are looking to start learning how to use a soldering iron or want to create a small portable gadget this set is a great chance "Simon Says" game educational set for learning with soldering iron which on the end you get a small electronic game. The goal of this game is to press buttons in order as they light up. With every correct answer, the game becomes harder and it is even possible to play "multiplayer"!
It is based on a microcontroller Attiny13, programmed in Arduino and on the back there is a battery that makes this gadget portable. Tutorial on how to solder this set are on the top right corner at "tutorials" and complete code and design is open-source (find it on GitHub!).
Set is based on: - printed circuit board - Attiny13 microcontroller - foothill for microcontroller - 4 LEDs - 4 Pushbuttons - 2 switches - 4 resistors of 330ohm - Battery holder - Battery CR2032
1-4 | $4.90 |
5-9 | $4.67 |
10-19 | $4.44 |
20+ | $4.21 |
Jordan | Nov. 2, 2020
Ships from Croatia.
9 Reviews | 281 Orders
$22.95
$7.95
$5.50
$3.95
$23.95
$16.95
$7.95
$2.95
