Reaction game is an educational kit which teaches you how to solder, and in the end, you get to have your own small game.
If you are looking for a simple way to learn soldering, or just want to make a small gadget that you can carry, this set is a great opportunity. Reaction game is an educational kit which teaches you …
Read More…If you are looking for a simple way to learn soldering, or just want to make a small gadget that you can carry, this set is a great opportunity. Reaction game is an educational kit which teaches you how to solder, and in the end, you get to have your own small game. The goal of the game is to press the button next to the LED as soon as it turns on. With every correct answer, the game gets a bit harder - the time you have to press the button shortens. How many correct answers can you get?
It's based on Attiny404 microcontroller, programmed in Arduino. At its back, you'll find CR2032 battery which makes the kit portable. There's keychain holder as well. Soldering process is easy enough based on the mark on the PCB.
The kit consists of: - PCB - Attiny404 microcontroller - 4 LEDs - 4 Pushbuttons - A switch - 4 resistors 330ohm - CR2032 battery holder - Battery CR2032 - Keychain holder
Find Reaction game Solder kit on Soldered website.
Enter your email address if you'd like to be notified when Reaction game Solder kit can be shipped to you:
Ships from Croatia.
9 Reviews | 281 Orders
$22.95
$7.95
$5.50
$3.95
$23.95
$16.95
$7.95
$2.95
