An accelerometer is a device that detects acting force on it in three directions (x,y,z).
Designed by e-radionica.com in Croatia
An accelerometer is a device that detects acting force on it in three directions (x,y,z). In sleep mode, it will detect a gravity force and when powering up it will detect all other forces that act o…
Read More…An accelerometer is a device that detects acting force on it in three directions (x,y,z). In sleep mode, it will detect a gravity force and when powering up it will detect all other forces that act on it. Because of it "feeling" gravity with this sensor you can measure and detect many things: hits, bias, movement, taping, footsteps, etc. Gyroscope on the other end is the possibility to detect orientation and angular velocity and will give more detailed information about the location of the object where it is also in three axes (x,y,z).
Specifically, this accelerometer measures forces all up to ±16 g and with speed up to 6700 measures per second. The gyroscope goes up to ±2000 DPS on 1700 measures per second. For their measures there is a FIFO buffer from 8kB, so your data will never be lost. It is not negligible that the device is extremely low-power and consumes a maximum of just over 1mA, and there are two interrupt pins.
Enter your email address if you'd like to be notified when LSM6DS3 gyroscope + accelerometer breakout can be shipped to you:
1-4 | $4.90 |
5-9 | $4.67 |
10-19 | $4.44 |
20+ | $4.21 |
Ships from Croatia.
8 Reviews | 219 Orders
Usually ships within 2 days
$159.00
$139.00
$11.99
$10.68
$4.11
$3.58
$19.87
$8.50
$349.00
