Since lithium batteries require special charging mode, and they should not be charged to the regular power source, you will need a charger.
$23.40
$33.60
$31.96 $39.95
Since lithium batteries require special charging mode, and they should not be charged to the regular power source, you will need such a charger. Budget friendly, together with an integrated CC / CV c…
Read More…Since lithium batteries require special charging mode, and they should not be charged to the regular power source, you will need such a charger. Budget friendly, together with an integrated CC / CV charging mode, definitely the easiest way to recharge the lithium battery. Input voltage can be connected via USB cable or a separate terminal. It should be noted that this is just the charger, but not a protection for the battery.
1-4 | $2.27 |
5-9 | $2.17 |
10-19 | $2.07 |
20+ | $1.97 |
Ships from Croatia.
9 Reviews | 281 Orders
$22.95
$7.95
$5.50
$3.95
$23.95
$16.95
$7.95
$2.95
