This module is a component that is able to detect the amount of humidity in the air.
$31.96 $39.95
$23.40
$33.60
This module is a component that is able to detect the amount of humidity in the air. Using the built-in comparator on its outputs gives either digital (HIGH / LOW) or analog (0V-5V) signal, depending…
Read More…This module is a component that is able to detect the amount of humidity in the air. Using the built-in comparator on its outputs gives either digital (HIGH / LOW) or analog (0V-5V) signal, depending on the severity of moisture.
Package includes: LM393 breakout, humidity sensor module and two jumper wires
1-4 | $4.11 |
5-9 | $3.92 |
10-19 | $3.73 |
20+ | $3.54 |
Ships from Croatia.
9 Reviews | 281 Orders
$22.95
$7.95
$5.50
$3.95
$23.95
$16.95
$7.95
$2.95
