This module is a component that is capable of detecting the magnetic field using Hall effect.
$33.60
$23.40
$19.50
This module is a component that is capable of detecting the magnetic field using Hall effect. Using this phenomenon, it can detect the presence of an object, current flowing through the conductor or …
Read More…This module is a component that is capable of detecting the magnetic field using Hall effect. Using this phenomenon, it can detect the presence of an object, current flowing through the conductor or measure speed. Using the built-in comparator on its outputs it gives either digital (HIGH / LOW) or analog (0V-5V) signal, depending on the strength of the magnetic field.
1-4 | $2.80 |
5-9 | $2.67 |
10-19 | $2.55 |
20+ | $2.42 |
Ships from Croatia.
9 Reviews | 281 Orders
$22.95
$7.95
$5.50
$3.95
$23.95
$16.95
$7.95
$2.95
$49.95
$21.99
