The adapter has two easyC connection ports and four plated through-holes: SCL, SDA, 3.3V, and GND.
Do you have an old I2C board lying around that would be perfect only if it had easyC connectors? With the easyC adapter and a little bit of soldering, you can give it new life. It will be able to con…
Read More…Do you have an old I2C board lying around that would be perfect only if it had easyC connectors? With the easyC adapter and a little bit of soldering, you can give it new life. It will be able to connect easily to newer boards with easyC cables.
The adapter has two easyC connection ports and four plated through-holes: SCL, SDA, 3.3V, and GND. It comes with pins that need to be soldered to the board.
Find easyC adapter on Soldered website.
Enter your email address if you'd like to be notified when easyC adapter can be shipped to you:
Ships from Croatia.
9 Reviews | 281 Orders
$22.95
$7.95
$5.50
$3.95
$23.95
$16.95
$7.95
$2.95
$17.50
