Small 3x5cm(1.2 x 2 inch) Arduino compatible board with Atmega328 and FTDI.
$31.96 $39.95
$23.40
$33.60
Croduino Basic is 100% Arduino compatible board made in EU(Croatia), created to promote Arduino culture in Croatia(well, it's named CROduino). Install Arduino software, plug it into USB and start DIY…
Read More…Croduino Basic is 100% Arduino compatible board made in EU(Croatia), created to promote Arduino culture in Croatia(well, it's named CROduino). Install Arduino software, plug it into USB and start DIY-ing!
It has even more analog inputs than Arduino Uno, features FTDI USB chip and built-in voltage regulator. The main difference from original Arduino and Croduino is size. Croduino is just 5cm x 3cm which makes it very easy to implement into projects. More:
Should be set up as "Arduino Nano w/ Atmega328" in Arduino software.
Project is OSH and files are available to download. If you need to use Croduino with Arduino shields, check our adapter.
If you need board without headers, please leave us a note when ordering.
This board has been manufactured in Croatia by e-r.io: Blog, Github, Web store.
1-4 | $14.89 |
5-9 | $14.09 |
10-19 | $13.39 |
20+ | $12.69 |
Ships from Croatia.
9 Reviews | 281 Orders
$22.95
$7.95
$5.50
$3.95
$23.95
$16.95
$7.95
$2.95
