This breakout is based on the ADS1115 ADC, which reads values in 16-bit resolution.
ADC (Analog Digital Converter) is a device that reads analog signals (just like the analogRead () function in Arduino IDE) and converts them into a digital signal that can be read by a microcontrolle…
Read More…ADC (Analog Digital Converter) is a device that reads analog signals (just like the analogRead () function in Arduino IDE) and converts them into a digital signal that can be read by a microcontroller. This breakout is based on the ADS1115 ADC, which reads values in 16-bit resolution, receives a maximum of 3.3V on its inputs and has a total of 4 channels (which can also be used as two differential). Works great with each microcontroller at 5V. It has 2 easyC connectors for easier connection on I2C communication.
You can find more about easyC at this link.
Find ADC 16-bit ADS1115 4-channel with PGA breakout on Soldered website.
Enter your email address if you'd like to be notified when ADC 16-bit ADS1115 4-channel with PGA breakout can be shipped to you:
Ships from Croatia.
9 Reviews | 281 Orders
$22.95
$7.95
$5.50
$3.95
$23.95
$16.95
$7.95
$2.95
$19.95
$21.95
$23.50
$25.50
