A relay is actually an electronic switch that is activated by a signal we send from a Dasduino or Arduino.
Did you ever wanted to turn on and off a device that needs large current or voltage? Whether operating on DC or AC, a relay is what you need. A relay is actually an electronic switch that is activate…
Read More…Did you ever wanted to turn on and off a device that needs large current or voltage? Whether operating on DC or AC, a relay is what you need. A relay is actually an electronic switch that is activated by a signal we send from a Dasduino or Arduino. This module further simplifies the whole process because it contains everything you need for the relay to work, and you just have to connect it to the microcontroller and power supply. You don’t have to think about voltages and currents, insulation between high and low voltage or grounding, everything is already taken care of on the board. This product has 4 relays.
Find 4-channel relay board on Soldered website.
Enter your email address if you'd like to be notified when 4-channel relay board can be shipped to you:
Ships from Croatia.
9 Reviews | 281 Orders
$22.95
$7.95
$5.50
$3.95
$23.95
$16.95
$7.95
$2.95
$11.96 $14.95
$19.96 $24.95
$24.76 $30.95
$26.36 $32.95
