If you are working with audio and need easy access to all the pins of the 3.5mm connector, this breakout makes it possible.
If you are working with audio and need easy access to all the pins of the 3.5mm connector, this breakout makes it possible. It accepts a male 3.5mm connector, in a 4-pin version, and allows access to…
Read More…If you are working with audio and need easy access to all the pins of the 3.5mm connector, this breakout makes it possible. It accepts a male 3.5mm connector, in a 4-pin version, and allows access to all connector pins on the header.
Find 3.5mm Jack breakout on Soldered website.
Enter your email address if you'd like to be notified when 3.5mm Jack breakout can be shipped to you:
Ships from Croatia.
9 Reviews | 281 Orders
$22.95
$7.95
$5.50
$3.95
$23.95
$16.95
$7.95
$2.95
$1.00
$6.99
