What is it? This is a cheap DIY metal seed phrase/recovery backup. When you setup a non-custodial crypto wallet, you are asked to securely backup a series of words (typically 24): This is your recove…
Read More…This is a cheap DIY metal seed phrase/recovery backup.
When you setup a non-custodial crypto wallet, you are asked to securely backup a series of words (typically 24): This is your recovery seed. With this seed you can recover your funds even if your wallet gets physically destroyed.
At some point you will be asked to write down your seed on a piece of paper (sometimes they even include the paper). The problem is that paper isn’t the most secure way to keep your backup seeds in the long run.
This is why metal backup seed are a thing. They keep your backup safe even in case of a fire or a flood or any natural disaster.
This year was absolutely crazy for cryptocurrency and if you are reading this there is a good chance that you are looking for a solution to secure your recovery seed without spending all your money on an overpriced steel wallet. You’ve probably already seen those, they can cost up to 249€. This is just ridiculous.
One day I came across this website made by Jameson Lopp where he put to the test the most populars metal seed storage solutions.
Turns out that the most expensive ones weren’t always the most robust. I was quite surprised to see the super popular Cryptosteel failed the tests.
The SAFU Ninja was the one that surprised me the most. It was a DIY solution that outperformed many commercial steel backup for a fraction of the cost.
Also this nice little jig can help you aligning the punches to make sure your seed is readable and pretty.
Also there is this really talented guy that machined a capsule with his metal lathe for his version of the SAFU Ninja.
But unfortunately not everyone have a metal workshop in his garage or easy access to a 3D printer...
So this is why I’ve put together this kit!
It's a fraction of the cost of all commercially available products. Seriously.
You will need some tools that aren't included (they are stupidly heavy and the shipping already cost more that the product itself)
You don’t need excessive force when stamping the washer. Doing so will likely end up in a warped washer.
Thin letters / numbers like L / I / J / T / 1 / 7 need less pressure to left a good trace. For instance if you use the same amount of force while stamping the letters « H » and « L » you will find that the « L » will go deeper than the « H ». Use the extra included washer to practice your swing ;)
Use masking tape under the washer to keep it in place.
I always get the « D » backwards no matter what (T_T) . Maybe you’ll succeed where I failed.
Enter your email address if you'd like to be notified when 42 HODL CAPSULE can be shipped to you:
Product: (4.00)
Documentation: (4.00)
Giuseppe | Oct. 7, 2021
$6.99
