Connects standard banana plugs to an electronic load (PCB only)
Designed by DJ4WD LabShack in GermanyThis seller is taking a break until Nov. 30, 2029. Sign up below to get an email when they're back!
This is a banana jack adapter PCB for a DC Electronic Load with binding posts (Maynuo, ITech, BK Precision or similar). Max electric current approximately: 10 Amps Screw mount contact spacing: 29…
Read More…This is a banana jack adapter PCB for a DC Electronic Load with binding posts (Maynuo, ITech, BK Precision or similar).
Screw mount contact spacing: 29.9 mm - 1.18" (standard)
Screw mount holes diameter: 6 mm
Banana Jack spacing: 19.05 mm - 0.75" (standard)
Banana Jack screw holes diameter: 4 mm (for M4 screws)
Lead-free
Colour white
YOU BUY JUST THE PCB!
Enter your email address if you'd like to be notified when DC Electronic Load Banana Plug Adapter (PCB only) can be shipped to you:
$6.90
$2.40
$2.70
$2.70
