Ultra-narrowband optical interference filter with a 780 nm center wavelength (CWL), a 2 nm full-width at half-maximum (FWHM)
Sold By AstroTech Ltd-Custom PCB and RF integrationFlea Market Item:
Angle of Incidence 0 Degrees Filter Design Multi-Cavity FWHM < 2.3 nm Center Wavelength 780 nm Nominal † Transmission Band(s) 780 nm > 90% T Absolute Blocking Level OD4 Blocking Range(s) OD4:…
Read More…Angle of Incidence
0 Degrees
Filter Design
Multi-Cavity
FWHM
< 2.3 nm
Center Wavelength
780 nm Nominal
Blocking Level
OD4
Dimensions
5.0 mm x 5.0 mm
Substrate Type
Fused Silica
Filter Thickness
2.0 mm
Assembly Type
Anodized Aluminum Ring
Assembly Thickness
3.5 mm
Enter your email address if you'd like to be notified when 780-2 OD6 Ultra Narrow Bandpass Filter can be shipped to you:
Prajnesh | Aug. 4, 2021
Flea Market Item:
Houghton, MI, United States of America
2 Reviews | 50 Orders
$63.00
$66.00
$87.95
