RF Fucker – Advanced RF Signal Analyzer & Generator for Security Testing
Designed by C1PH3R-FSOCITEY in IndiaNo shipping info available.
Unlock the hidden world of radio frequencies with the RF Fucker, a versatile RF signal cloning, generation, and analysis tool designed for penetration testers, security researchers, and wireless engi…
Read More…Unlock the hidden world of radio frequencies with the RF Fucker, a versatile RF signal cloning, generation, and analysis tool designed for penetration testers, security researchers, and wireless engineers. This compact device empowers you to capture, replay, and analyze RF signals across common frequencies (315MHz, 433MHz, and more), making it indispensable for testing wireless systems, reverse engineering protocols, and hardening security defenses.
Key Features & Capabilities 🔹 RF Signal Cloning Record and replay RF signals to test system resilience against replay attacks. Perfect for evaluating security systems (e.g., garage doors, sensors, IoT devices).
🔹 Multi-Frequency Signal Generation Generate random signals at 315MHz, 433MHz, and other frequencies. Simulate devices or test compatibility with RF-based systems.
🔹 Signal Analysis & Protocol Inspection Capture and analyze RF signals in real-time. Measure signal strength, modulation, and timing for reverse engineering.
🔹 Raw RF Data Capture Extract raw signal data for advanced analysis or custom processing. Compatible with software-defined radio (SDR) tools for deeper research.
🔹 Broad Frequency Range Supports common ISM bands for maximum versatility.
🔹 User-Friendly Interface Intuitive controls for signal capture, replay, and generation. Expandable via open-source firmware (e.g., ESP32-based).
Legal & Ethical Use Cases ⚠ Warning: This device is for authorized testing only.
Penetration Testing: Audit wireless systems you own or have permission to test. Security Research: Identify vulnerabilities in RF protocols (e.g., rolling codes, fixed codes). IoT Development: Test device resilience against RF interference or spoofing. Education: Learn about RF communication, signal analysis, and defensive design. Never use for unauthorized access. Compliance with local laws is mandatory.
Technical Specifications Core Module: ESP32 Frequency Range: 315MHz, 433MHz. Connectivity: USB for data export/firmware updates.
What’s Included? 1× RF Fucker Device Quick Start Guide (Online Documentation + Legal Disclaimer)
Why Choose This Tool? ✔ Open-Ended Hacking: Flash custom firmware (e.g., expand with Arduino/Rust). ✔ Research-Grade: Ideal for labs, red teams, or wireless hobbyists. ✔ Privacy-Conscious Design: No backdoors or data logging.
Enter your email address if you'd like to be notified when RF Fucker can be shipped to you:
All products sold are intended strictly for ethical hacking, security research, and educational purposes only. The buyer is solely responsible for complying with all applicable laws in their region. C1PH3R-FSociety is not liable for any misuse or illegal activity involving these devices. All intellectual property, including device designs and branding, remains the property of C1PH3R-FSociety. Buyers must be 18+ years old. Use of our products implies agreement to these terms.
$49.99
$34.30 $35.00
$244.00
$139.00
$257.61
