This is a PCB board to replace the 3DS xl charging port so you can use USB-C cables to charge (usb-c to usb-c charging)
This is a PCB USB-C charging port to replace the original charging port on the 3DS-XL, this port works with USB-C to USB-C cable charging so you don't need to worry about having a USB to USB-C cable.…
Read More…This is a PCB USB-C charging port to replace the original charging port on the 3DS-XL, this port works with USB-C to USB-C cable charging so you don't need to worry about having a USB to USB-C cable.
The Installation jig allows you to solder down the castellated holes while holding the PCB in perfect alignment, a thumb screw is provided for easy assembly and disassembly of the jig.
While I've tested the jig on a few 3DS XL boards I can't guarantee a perfect fit so some sanding may be required, do to the heat of the iron I consider the jig to be a mostly single use item. In testing I get ~5.1 V and .75A while charging. I do not preserve the old gold contacts of the 3DS XL.
REQUIRED BUT NOT INCLUDED TOOLS: 1. A soldering Iron 2. Flux 3. Solder 4. Screwdrivers 5. Multimeter
(highly) RECOMMENDED BUT NOT INCLUDED TOOL: 1. Hot air station 2. Hot plate
INCLUDED: 1. USB-C PCB board fully assembled 2. 6-32 thumbscrew (same kind used in computer cases) 3. 3D Printed Installation Jig 4. 3D Printed bezel
Enter your email address if you'd like to be notified when 3DS XL USB-C Mod charging port w/ jig can be shipped to you:
