The Neuron is a learn to solder kit made for the 2012 Kansas City Maker Faire. On the surface it's just another easy to assemble "my first soldering project" blinker, but put a few of them together a…
Read More…The Neuron is a learn to solder kit made for the 2012 Kansas City Maker Faire. On the surface it's just another easy to assemble "my first soldering project" blinker, but put a few of them together and you can make a light and touch reactive light show!
It functions as your typical alternating LED blinker with a jumper in place, but remove the jumper and they mirror pulses of light detected on one LED to the other. Chain a large set of them together and they'll activated each other in sequence. They're also bi-directional so you can send a pulse one direction in a chain and send another back the opposite direction. A single Neuron firing can activate more than one Neuron, forming branching light shows as well! You can even use one in blink mode to act as a convenient light pulse source.
The kit includes everything you need to get your Neuron up and running including batteries!
Source files and video links can be found here: http://www.thingiverse.com/thing:31229
Full assembly instructions can be found here: http://www.built-to-spec.com/blog/kit-instructions/neuron-build-instructions/
Kansas City, MO, United States of America
20 Reviews | 305 Orders
$5.50
$10.50
$10.50
$8.50
$11.89 $13.99
$3.99
$16.14 $18.99
$4.97 $9.95
