Nordic nRF5340 BT5.2 (Bluetooth/Zigbee/Thread/ANT+) LE Audio Mulitprotocol FCC/IC/CE/Telec/KC/ SRRC/NCC Pre-Certified Module
Raytac’s MDBT53V & MDBT53V-P is a BT 5.2 stack (Bluetooth low energy or BLE) module designed based on Nordic nRF5340 SoC solution, which incorporates: GPIO, SPI, UART, TWI, I2S, PDM, PWM, ADC, NFC an…
Read More…Raytac’s MDBT53V & MDBT53V-P is a BT 5.2 stack (Bluetooth low energy or BLE) module designed based on Nordic nRF5340 SoC solution, which incorporates: GPIO, SPI, UART, TWI, I2S, PDM, PWM, ADC, NFC and USB interfaces for connecting peripherals and sensors.
Part No. MDBT53V-1M / Chip Antenna / 7.8 x 12.4 x 1.85mm MDBT53V-P1M / PCB Antenna / 7.8 x 12.4 x 1.6mm
Enter your email address if you'd like to be notified when nRF5340 BT5.2 Antenna Module Raytac MDBT53V can be shipped to you:
Ships from Taiwan.
3 Reviews | 217 Orders
$9.98
$19.98
