We are seeing many shipping delays, especially for international orders. Please check individual product pages for details. More info on COVID-19 and Shipping
Nordic nRF52832 BT5 Bluetooth u.FL Antenna Module FCC CE IC MIC Telec KC SRRC NCC RCM Pre-Certified
MDBT42Q-U512KV2 (nRF52832 Build Code#E SoC) Raytac’s MDBT42Q & MDBT42Q-P is a BT5.2 & BT4.2 stack (Bluetooth low energy or BLE) module designed based on Nordic nRF52832 SoC solution, which incorpor...
Read More…MDBT42Q-U512KV2 (nRF52832 Build Code#E SoC) Raytac’s MDBT42Q & MDBT42Q-P is a BT5.2 & BT4.2 stack (Bluetooth low energy or BLE) module designed based on Nordic nRF52832 SoC solution, which incorporates: GPIO, SPI, UART, I2C, I2S, PWM and ADC interfaces for connecting peripherals and sensors.
MDBT42Q-U512KV2 is the module designed based on u.FL connector which is able to connect to external antenna which is the optimized solution for those design pursue a better RF efficiency.
Certification:
(Regulation is tested under Raytac's selected antenna)
About The Module:
Compact size with (L) 13.8 x (W) 8.8 x (H) 2.2 mm.
Features:
‧Multi-protocol 2.4GHz radio
‧RSSI
‧Dynamic on-air payload length up to 256 bytes ‧Flexible and configurable 32 pin GPIO
‧1 x UART (CTS / RTS)
‧PDM for digital microphone
‧I2S for audio
‧Quadrature demodulator
‧12-bit / 200KSPS ADC
‧On-chip DC/DC buck converter
‧Timer counter
‧5 x 32-bit
‧3 x 24-bit RTC
Enter your email address if you'd like to be notified when nRF52832 BT5.2 Module u.FL For External Antenna can be shipped to you:
Ships from Taiwan.
2 Reviews | 81 Orders
Usually ships within 1 day
