Nordic Solution AT Command Slave/Peripheral Bluetooth Module UART SPP Service Raytac MDBT42Q Series
Raytac's AT Command Module (Salve/Peripheral) Bluetooth Certification: BT5.2 & BT5.1 & BT5.0 & BT4.2 Safety Regulation Compliance: FCC (USA) / IC (Canada) / CE (EU) / Telec (Japan) / SRRC (China) / K…
Read More…Raytac's AT Command Module (Salve/Peripheral)
Bluetooth Certification: BT5.2 & BT5.1 & BT5.0 & BT4.2 Safety Regulation Compliance: FCC (USA) / IC (Canada) / CE (EU) / Telec (Japan) / SRRC (China) / KC (Korea) / NCC (Taiwan)
About The Module:
Nordic nRF52811 Solution Compact size with (L) 16 x (W) 10 x (H) 2.2 mm.
Antenna Option
Enter your email address if you'd like to be notified when AT Command Slave SPP BT5.2 Antenna Module MDBT42Q can be shipped to you:
Ships from Taiwan.
3 Reviews | 222 Orders
$1.87 $2.20
$14.90
$4.98
