Nordic BT5 Solution AT Command Master/Central Bluetooth Module UART SPP Service SPP Raytac MDBT42Q Series
Raytac's Modules 100% Made In Taiwan; No worry about the Trade War Risk With China! Raytac's AT Command Module (Master/Central) Certification: Bluetooth: BT5.2 & BT5.1 & BT5 & BT4.2 Regulation: F…
Certification:
About The Module:
Nordic nRF52832 Solution
CompCompact size with (L) 16 x (W) 10 x (H) 2.2 mm.
Antenna Option
Enter your email address if you'd like to be notified when AT Command Master BT5.2 Antenna Module MDBT42Q can be shipped to you:
Ships from Taiwan.
3 Reviews | 217 Orders
$4.98
$6.30
$6.30
