Revive your old PC with new powerfull reused CPU Dual / Quad Intel® Core™2 Quad or Core™2 Duo. Individually tested 100% OK
Reused Intel® Dual and Quad core CPU for your old desktop PC Options: Q9550 , Q6600 , Q9950S , Q9500 , E8600 , E8500 E8500 --> 6MB Cache 2x 3.16 GHz 1333 MHz FSB 65W TDP E8600 --> 6MB Cache 2x …
Read More…Reused Intel® Dual and Quad core CPU for your old desktop PC
Did you know that the CPU is the strongest component on the computer? It's virtually impossible to destroy a cpu, only through bad user installations or bad power supplies. The CPU is designed to handle lots of heat and high current. CPU will live virtually for ever!
Is your old Desktop PC super slow?
Can't run new applications and programs because of no resources? Can't game? Keep it stored in the basement because you don't use it? No. Throw it away? No. Under developed countries receive millions of tons of e-trash every day. Electronic components are a big problem, so they must be reused!
Here is the solution to revive, reuse and give new life to your old Desktop PC, while saving money. Low cost upgrades and amazing performance on old machines: Windows XP , Windows 7 , 8 , 10 , Linux and mac OS faster than ever! Your old computer gets a new life for gaming, as a server, virtual machine, video editing, multimedia applications, simply as a browser, paint & office in a super fast machine.
There are four essential machine elements:
First is the power source. A good power source gives a nice stable, filtered feed to electronic components.
Second is the brain of computer, the CPU Processor. Make sure it has plenty of cache memory and high speed Front side bus FSB. Some dual cores can perform better than quad core because they have more cache L memory, but of course more clock speed is better. Lower transistor gate size lithography means there is less heat produced and less power consumed. Remember to always use thermal grease to ensure perfect heat dissipation.
Third is the memory to store temporary information. 1333MHz and DDR2 is top speed for older generation PC's and you can combine similar pair modules to get dual channel bandwidth on supported dual channel motherboards.
Fourth is the hard disk drive. Make sure it has low latency data access/write and a high data transfer rate. SATA2 is for older generation PC's and it can transfer 250Mb-300Mb/s. Use a SSD solid state drive to store the operating system, program applications, and most accessed files. SSD uses full potential of sata2 channel speed bandwidth and has very low latency compared to traditional HDD. Windows 7 can load in less than 8 seconds on an old machine with a quad core CPU and SSD. With a SSD opening a program, application, or file is almost instantaneous. You can use the primary disk SSD and secondary regular HDD disk for file storage purposes.
The first step is to know the model of your motherboard. Check all info and labels on the motherboard to know its model and to check the cpu's supported and type of memory. Google for reference/references to know more about your motherboard. This upgrade is for socket LGA775 so make sure your board socket is 775 (most used in the world).
You can choose between these CPU's according to your budget, requisites, and motherboard supported cps's.
--Check the anex pdf file on the documentation section to know more about these CPU's and compare to help you choose the best option for you.-- For more details about the full technical specifications of CPU go here and search for the model.
All CPU's are re-tested before shipping. Reused cpu's from old desktop secretary pc's (light weight tasks office, browser) 100% fully working and guaranteed. Save money and learn to reuse / resell old stuff for a better eco system.
Free thermal paste included. Quick delivery worldwide. Tracked and protected package.
Please check out my other products . Maybe there is something useful or of your interest. You will find amazing products of your interest. New cool products added every week. I have tindie and eBay stores below. Check both if you want. Make sure to open in new separator. Thanks for your time
Enter your email address if you'd like to be notified when Desktop PC UPGRADE Revive old PC Intel® Quad Core™ can be shipped to you:
$24.90
$40.95
$22.50
$29.80
$26.30
$19.90
$145.00
$247.00
$38.95
