Easy power solution for Atomic Pi with additional USB 2.0 port. Improvements over the Digital Loggers official hat boards.
Limited run item. Sorry, no longer in production. 2 Useful add-on boards for Atomic Pi add convenient power input and a USB 2.0 port. Available with 12v or 5v input voltages. The 12v input version (…
Read More…The 12v input version (with regulator) supplies the Atomic Pi with 5v and 12v. The 12v supply is needed to utilize the Atomic Pi's built in stereo speaker amplifier.
These boards feature a more compact design and easier case mounting compared to official Digital Loggers breakout boards.
Provides 12v and regulated 5v at up to 6A from a single 12v supply to Atomic Pi's 26 pin GPIO connector without soldering required. Securely mounts to Atomic Pi using included screws and spacers. A heavy duty on/off switch and power on LED are located on the front of the assembled system. Power input is provided through a 5.5mm x 2.1mm center pin positive barrel jack.
The 5v version does not have the 12v - 5v regulator and does not provide 12v to the Atomic Pi's onboard audio amplifier.
GPIO 0-5 and UART 1-2 breakout pads are provided for adding additional I/O circuitry.
Optional feature: A momentary tact switch can be soldered to the Atomic Pi's power button pads using 30ga wire. This button can be set to shut down or sleep depending on the OS.
This included PCB plugs into the webcam connector of the Atomic Pi and provides a USB 2.0 jack. Mounts securely to Atomic Pi with a 3mm screw and nylon spacer.
Thanks for looking!
30 Reviews | 1,360 Orders
$39.95
$87.00
$89.00
