Relay module enables control over consumers which require high voltages or high currents, regardless of whether they are connected to DC/AC.
Relay module enables control over consumers which require high voltages or high currents, regardless of whether they are connected to direct or alternating voltage. The relay is an electronic switch …
Read More…Relay module enables control over consumers which require high voltages or high currents, regardless of whether they are connected to direct or alternating voltage. The relay is an electronic switch triggered by the signal we send from Croduino / Arduino. This module allows easy relay usage with a direct connection to the pins of your Croduino or Arduino.
1-4 | $3.58 |
5-9 | $3.42 |
10-19 | $3.26 |
20+ | $3.09 |
Ships from Croatia.
9 Reviews | 281 Orders
$22.95
$7.95
$5.50
$3.95
$23.95
$16.95
$7.95
$2.95
$16.76 $20.95
$36.00
