BME280 is an atmospheric sensor which measures 3 values: temperature, pressure, and humidity.
$31.96 $39.95
$23.40
$33.60
BME280 is an atmospheric sensor which measures 3 values: temperature, pressure, and humidity. Besides, it is possible to calculate elevation. It is simple to use since it communicates via I2C and it …
Read More…BME280 is an atmospheric sensor which measures 3 values: temperature, pressure, and humidity. Besides, it is possible to calculate elevation. It is simple to use since it communicates via I2C and it is extra small sized so it can be put anywhere. Everything you need to know about the atmospheric condition - this sensor can measure for you; just ideal for meteo station projects! This board comes with two easyC connectors and provides easy connections.
1-4 | $13.30 |
5-9 | $12.65 |
10-19 | $12.00 |
20+ | $11.35 |
Ships from Croatia.
9 Reviews | 281 Orders
$22.95
$7.95
$5.50
$3.95
$23.95
$16.95
$7.95
$2.95
$15.70
