This is the APtech ADXL335 accelerometer breakout board, good for gaming projects robotics and maybe even drones, very simple to use, just connect the ZOUT YOUT XOUT pinouts to the Arduino analog pin…
Read More…This is the APtech ADXL335 accelerometer breakout board, good for gaming projects robotics and maybe even drones, very simple to use, just connect the ZOUT YOUT XOUT pinouts to the Arduino analog pins and read the values with an analog read function, Arduino and Processing codes available in source code, and it dose work with codes and libraries that are already available on the web so check it out, warning power 3v3 only.
24x32mm
Self-Test.
Z Channel Output.
Y Channel Output.
X Channel Output.
Power warning 3v3 only
Ground
$120.00
$7.40
$330.00
$5.70
$27.00
$22.95
